Time
Time
Does anyone's site show the correct time after Day Light Savings time from a couple weeks ago? Mine is running an hour fast and wanted to ask the users before I go in and change things.
Re: Time
Yeah now that you mention it mine is an hour fast too. I guess I never noticed.
Re: Time
Users will have to change their time themselves. The one I can change will only affect guests or those not signed in.
How to change your time:
User Control Panel > Board preferences > Edit global Settings
Change “Summer Time/DST is in effect:” to No
I tested this and it works.
Re: Time
Aww man, I'm not posting from the future anymore.
Re: Time
worked for me too!
Re: Time
Remember that you have to manually fix your time.
Re: Time
Remember to change your time from a couple weeks ago if you haven't yet.
Change “Summer Time/DST is in effect:” to Yes
Re: Time
Can you change the default for all users, at least new users, to have Daylight Savings Time turned on?
Time
Possibly. I'll try to look into this next week. I think I failed at it once before.
Re: Time
Re: Time
Mine changed automatically?
- DannyFanny
- Top Contributor
- Contact:
Re: Time
This
Re: Time
test
Re: Time
mine's off but can't say I really noticed the time before so doesn't bother me haha
Time
Tyler wrote:Source of the post How to change your time:
This no longer applies since switching over to the new theme (I don't even what CPT looked like before!)
I changed the time in my profile from -5 to -4.
Return to “Rules, Announcements, and Feedback”
Users browsing this forum: No registered users and 3 guests
