Woodworking
Re: Woodworking
Postby Tyler » Sun Feb 07, 2016 3:30 pm
Huss Buss wrote:this was fun to do since using all the tools..thanks glass.
You're welcome for driving 4 hours to help me with my basement?
jathko87
Re: Woodworking
Postby jathko87 » Sun Feb 07, 2016 8:13 pm
DannyFanny wrote:
jathko87 wrote:Wow your neighbor is creeping in your window kyle needs to help you put up a fence
Or a nice big shed
Great idea!
Re: Woodworking
Postby Tyler » Sun Feb 21, 2016 5:37 pm
Been wanting to replace my vibrating hand sander with a random orbital. Couldn't pass on this for $18 at Walmart. Will be using it in a couple weeks when I start on my desk, TV shelf, and book case.
Re: Woodworking
Postby Tyler » Wed Mar 16, 2016 7:13 am
Ckrjack and I started our TV shelves yesterday. Building a 3rd for cwilkins. We tried cutting everything with a skillsaw before I had my table saw, had to cut everything again since nothing was cut well enough. Table saw works great. Huss Buss 2 is borrowing it now actually.
Next up is sanding and adding the veneer edging to the exposed edge.
Re: Woodworking
Postby bmyoungs » Wed Mar 16, 2016 6:37 pm
Looks cool might do something similar in ours
Re: Woodworking
Postby wags83 » Wed Mar 16, 2016 7:33 pm
Neato!
Re: Woodworking
Postby Tyler » Mon Mar 21, 2016 8:21 am
Helped my dad with his jointer table while I was home. Really cool design that a foot pedal lifts it up so you can roll it around and then you can drop it down on the legs. I mounted the motor, got the belt fitted, and wired the switch. The motor turns the wrong way though and we couldn't figure out how to reverse the polarity of it.
Re: Woodworking
Postby Tyler » Sat Apr 02, 2016 9:41 am
Got my TV shelf hung that I made and the cabinet door my dad made for me to cover the electrical panel.
Re: Woodworking
Postby Tyler » Sat Apr 02, 2016 4:03 pm
Eagerly waiting for Huss Buss to post his approval....
Huss Buss
Re: Woodworking
Postby Huss Buss » Sat Apr 02, 2016 7:24 pm
man that looks nice!! likely the colors matching the furniture. are they stained or painted?
also base board looks good
Re: Woodworking
Postby Tyler » Sat Apr 02, 2016 7:29 pm
Stained espresso. It matches the end table we bought and the thing that holds Evie's toys. TV trays do not match.
Huss Buss
Re: Woodworking
Postby Huss Buss » Sat Apr 02, 2016 7:35 pm
Tyler wrote:Stained espresso. It matches the end table we bought and the thing that holds Evie's toys. TV trays do not match.
good color.. good job
Re: Woodworking
Postby Tyler » Wed Apr 06, 2016 11:02 am
This seems like a neat idea for someone living in an apartment or doesn't have room for shop, but I can't imagine the tools are very powerful.
Shopsmith is a similar concept, but seems much stronger. You can also add attachments to it like a band saw
http://www.shopsmith.com/markvsite/index.htm
[youtube]AvV1gmghOEk[/youtube]
blake
Re: Woodworking
Postby blake » Wed Apr 06, 2016 12:18 pm
Ron Swanson would approve this thread
Woodworking
Postby Tyler » Fri Jan 06, 2017 8:02 am
Waiting for pics of Brad's workbench
Woodworking
Postby bmyoungs » Sun Jan 08, 2017 3:57 am
Tyler wrote:Waiting for pics of Brad's workbench
Didn't end up getting any peg board. It is all clean now though.
Woodworking
Postby Tyler » Sun Jan 08, 2017 9:36 am
bmyoungs wrote:Source of the post It is all clean now though.
Pics or bs
Woodworking
Postby bmyoungs » Sun Jan 08, 2017 3:18 pm
Pics or bs
Re: Woodworking
Postby Tyler » Sun Jan 08, 2017 4:28 pm
You proved it. That thing looks heavy and sturdy. Doubled up 2x4 legs. Dang.
Woodworking
Postby bmyoungs » Sun Jan 08, 2017 4:37 pm
Tyler wrote:You proved it. That thing looks heavy and sturdy. Doubled up 2x4 legs. Dang.
Yeah it's extremely sturdy, haven't really had much actual use for it yet. Now that it's not covered in junk it can be used if I need to.
Users browsing this forum: No registered users and 1 guest
