Woodworking
Woodworking
Postby wags83 » Fri Sep 29, 2017 2:02 pm
Has anyone ever used SketchUp before? I think I'm going to download it tonight and try to plan out how I want my bar to look.
Huss Buss
Woodworking
Postby Huss Buss » Sat Sep 30, 2017 7:18 am
wags83 wrote:Source of the post Has anyone ever used SketchUp before? I think I'm going to download it tonight and try to plan out how I want my bar to look.
i have google SketchUp 8.
i used it from my parents patio area, and i done a few smaller landscaping areas. its pretty once you get use to it.
Re: Woodworking
Postby Tyler » Sat Sep 30, 2017 8:12 am
I've used it before. Learning curve was a too steep when I tried it years ago so I just drew it out on paper
Woodworking
Postby Tyler » Sat Jan 06, 2018 11:03 pm
Re: Woodworking
Postby Corey » Sun Jan 07, 2018 12:57 am
I built this table last week. The chairs are from IKEA.Image
Re: Woodworking
Postby Tyler » Sun Jan 07, 2018 9:08 am
I'm very impressed Corey. What did you seal it with? How soft does the top of it feel?
Huss Buss
Woodworking
Postby Huss Buss » Sun Jan 07, 2018 9:30 am
Tyler wrote:Source of the post I'm very impressed Corey. What did you seal it with? How soft does the top of it feel?
werd! great job! i like how it matches the floor
Re: RE: Re: Woodworking
Postby Corey » Sun Jan 07, 2018 10:27 am
Tyler wrote:I'm very impressed Corey. What did you seal it with? How soft does the top of it feel?
3 coats of oil based polyurethane. It doesn't feel soft at all. You can't dig a fingernail into it or anything like you would before the poly.
Re: RE: Re: RE: Re: Woodworking
Postby Tyler » Sun Jan 07, 2018 10:36 am
That's great. Our cheap table from the store that shall not be mentioned is so soft that it leaves marks in the wood when using a pen to write on paper.
Woodworking
Postby wags83 » Sun Jan 07, 2018 3:33 pm
Turned out really good. Probably because of having a table saw available to use.
Huss Buss
Woodworking
Postby Huss Buss » Sun Jan 07, 2018 4:39 pm
wags83 wrote:Source of the post Turned out really good. Probably because of having a table saw available to use.
hahaha.. table saws are handy
Woodworking
Postby wags83 » Sun Jan 07, 2018 5:13 pm
Huss Buss wrote:Source of the post
He borrowed mine and never used it.
Re: Woodworking
Postby Tyler » Sun Jan 07, 2018 5:47 pm
You didn't use the table saw for this? Kept all the top planks at factory width?
Postby Corey » Sun Jan 07, 2018 6:10 pm
Tyler wrote:You didn't use the table saw for this? Kept all the top planks at factory width?
Werd. Much less work
Woodworking
Postby Tyler » Sun Jan 07, 2018 8:20 pm
One last question, can you even feel the cracks between the boards after sealing it?
Re: RE: Woodworking
Postby Corey » Sun Jan 07, 2018 10:56 pm
Tyler wrote:One last question, can you even feel the cracks between the boards after sealing it?
Yes you can. The poly doesn't affect the cracks that much. To not have the cracks you'd have to have perfect boards with perfect 90s on the edges. I was considering attempting this with the table saw but didn't think I'd do a good job with it so I left them and went for the more rustic feel.
Re: RE: Re: RE: Woodworking
Postby Tyler » Sun Jan 07, 2018 11:06 pm
Or super thick sealant?
90 degrees are what table saws are for! You could have done it.
Re: Woodworking
Postby Corey » Tue Apr 24, 2018 10:44 pm
Got a new to me tool chest today and got my tools all organized. They were mostly strewn about the bottom of my work bench and would get coated with sawdust anytime I used the saw. Still want to get some bins to put the bigger power tools in and put them on the bottom of the work bench. Right now they are just on a wire rack. Image
Re: Woodworking
Postby Tyler » Wed Apr 25, 2018 6:23 am
Looks great and clean. Too clean....like you don't have any tools. This would explain why you didn't chat all night. Busy buying and organizing.
Did you try to haggle after the guy was an hour late?
Woodworking
Postby wags83 » Wed Apr 25, 2018 7:47 am
Looks very organized now!
Users browsing this forum: No registered users and 7 guests
