Favorite Mobile Apps
Re: Favorite Mobile Apps
Postby ejhartman91 » Mon Feb 22, 2016 2:02 pm
Tyler wrote:Speaking of apps...ejhartman91 do you subscribe to threads through Tapatalk? It seems threads you reply to very quickly whereas others go ignored for you.
If I had to guess I would say you are subscribed to this and the CW show threads. Do you get a notification when a post is submitted?
Yes. I'm subscribed to this and the three cw shows and I get notified for posts on those but nothing else.
Postby Tyler » Mon Feb 22, 2016 2:16 pm
ejhartman91 wrote:Yes. I'm subscribed to this and the three cw shows and I get notified for posts on those but nothing else.
Does that drive you crazy during the day? Omg, you are getting a notification because of this post. Sorry!
itscsalvo
Postby itscsalvo » Mon Feb 22, 2016 2:18 pm
Back to the topic of Google Opinion Rewards
$62.09 since 12/16/14. Currently at $9.17 and I have no idea what to spend it on.
Postby ejhartman91 » Mon Feb 22, 2016 2:24 pm
itscsalvo wrote:Back to the topic of Google Opinion Rewards
Lately I've been buying watch faces for my Android wear watch. I used to rent movies from Google play a lot
itscsalvo
Postby itscsalvo » Mon Feb 22, 2016 3:13 pm
Honestly, those are probably some of the better ideas I've heard. Much better than "buy this in-app purchase" or "get this app you'll never use."
Postby ejhartman91 » Mon Feb 22, 2016 3:17 pm
itscsalvo wrote:Honestly, those are probably some of the better ideas I've heard. Much better than "buy this in-app purchase" or "get this app you'll never use."
Well if you don't have weather timeline (https://play.google.com/store/apps/deta ... on.weather), I highly recommend it. Best weather app by far IMO.
Postby Tyler » Mon Feb 22, 2016 3:49 pm
ejhartman91 wrote:Well if you don't have weather timeline (https://play.google.com/store/apps/deta ... on.weather), I highly recommend it. Best weather app by far IMO.
Don't have a "nice" weather app, I just swipe left and use Google Now. Just bought. Thanks.
itscsalvo
Postby itscsalvo » Mon Feb 22, 2016 8:59 pm
Tyler wrote:Don't have a "nice" weather app, I just swipe left and use Google Now. Just bought. Thanks.
I do the same thing. I use it when I'm getting ready in the morning, mainly Google Now. This app is looking pretty great, though.
Postby bmyoungs » Mon Feb 22, 2016 9:34 pm
Just put it on my phone, best transparent weather widget yet. Thanks
Sent from my VK815 using Tapatalk
Postby Tyler » Mon Feb 22, 2016 10:07 pm
I made mine transparent too. Let's see what it looks like with your Nova pro
Postby bmyoungs » Tue Feb 23, 2016 11:56 am
Postby bmyoungs » Tue Feb 23, 2016 11:58 am
Also yes I am in Florida at the moment.
Postby wags83 » Tue Feb 23, 2016 7:09 pm
Nice!
Postby Tyler » Thu Feb 25, 2016 3:59 pm
I have a handful of numbers that I block because they call me all the time about junk. Android still gives me a notification when I get the call and it's blocked. Is there an app that blocks the call and doesn't alert me of it? Maybe even offers a block log if I ever carried to look up the blocked numbers?
Postby ejhartman91 » Thu Feb 25, 2016 4:04 pm
Tyler wrote:I have a handful of numbers that I block because they call me all the time about junk. Android still gives me a notification when I get the call and it's blocked. Is there an app that blocks the call and doesn't alert me of it? Maybe even offers a block log if I ever carried to look up the blocked numbers?
On stock Android, you can set contacts to "send all calls to voicemail." So I created a contact called "do not answer and set all calls for it to voicemail. I don't get notified when they call, but the calls still show in my call log list.
If that doesn't work for you, try this app:
https://play.google.com/store/apps/deta ... truecaller
Postby Tyler » Thu Feb 25, 2016 7:48 pm
My problem is it's more than just one number I'm blocking. How many numbers can I add to a contact? I'll try the app out too
Postby ejhartman91 » Thu Feb 25, 2016 7:57 pm
Tyler wrote:My problem is it's more than just one number I'm blocking. How many numbers can I add to a contact? I'll try the app out too
I don't think there's a limit to the amount of numbers a contact has. I know I have at least 5 on mine...
Postby Tyler » Fri Mar 04, 2016 8:12 am
Been using this app for over a week now. I really like it. When you get a call it must search google for it and a Caller ID shows who is calling, even if you don't have their number. I got a call yesterday from my local insurance and it showed his name and picture.
The app is also blocking a lot of spammer calls and tells you what they are. I still get a notification for them, but I can live with it since it is doing a better job of blocking calls than I was. I assume I can change settings or turn off notifications for the entire app, but I like how it is working now.
Postby bmyoungs » Fri Mar 04, 2016 10:18 am
Must have missed this one giving it a whirl now
Postby ejhartman91 » Tue Mar 08, 2016 1:17 pm
http://www.androidcentral.com/truecalle ... new-dialer
Pretty decent looking update for Truecaller...
Users browsing this forum: No registered users and 3 guests
