Wags's bar project
Wags's bar project
Postby Tyler » Sun Mar 25, 2018 10:05 pm
This diserves it's own thread. Let's see the plans you drew up, the lumber you were gifted, and how far you got this weekend.
Wags's bar project
Postby wags83 » Mon Mar 26, 2018 8:11 am
I didn't get super far. Mostly just cleaning up the wood all day Saturday and yesterday I started gluing the planks together for the bar top.
I'll get some pictures tonight after work.
Re: RE: Wags's bar project
Postby Tyler » Mon Mar 26, 2018 9:36 am
wags83 wrote:I didn't get super far. Mostly just cleaning up the wood all day Saturday and yesterday I started gluing the planks together for the bar top.
You should have used Corey's Kreg rig for the top
Wags's bar project
Postby wags83 » Mon Mar 26, 2018 9:59 am
Tyler wrote:Source of the post
But I haven't needed to rip anything yet. I will though when I get the plywood for underneath it. But I'm a man and I have a table saw.
blake
Wags's bar project
Postby blake » Mon Mar 26, 2018 10:24 am
was hoping Wags was opening his own tap room bar
Re: Wags's bar project
Postby Tyler » Mon Mar 26, 2018 10:33 am
I don't mean his saw tool, I mean his Kreg drill tool. It's specifically meant for screwing wood together that's butting up against each other.
Wags's bar project
Postby wags83 » Mon Mar 26, 2018 10:53 am
Tyler wrote:Source of the post I don't mean his saw tool, I mean his Kreg drill tool. It's specifically meant for screwing wood together that's butting up against each other.
Ohhhh, I see. I have a Kreg jig for pocket holes. It's just a basic one though, I believe there are fancier ones out there. I thought about doing it that way, but I think it will be stronger this way and easier.
Wags's bar project
Postby wags83 » Mon Mar 26, 2018 10:54 am
blake wrote:Source of the post was hoping Wags was opening his own tap room bar
Haha not quite. But now I'll have a bar in my basement where I can drink my homemade beer, so I guess it's close!
Wags's bar project
Postby wags83 » Mon Mar 26, 2018 8:03 pm
Not a ton to look at yet but here are some pics.
Some of the wood in it's original state. Comparison of old dirty wood vs. cleaned up. And the bar top being glued up. ImageImageImageImage
Postby Tyler » Mon Mar 26, 2018 8:11 pm
That looks great! 1/4inch play behind it? What are the dimensions?
Wags's bar project
Postby wags83 » Mon Mar 26, 2018 8:13 pm
Actually what you're seeing is the bottom so plywood will go on that side. The base will be 6 feet and the bar top is a bit longer than that so there will be some overhang on the end. As it is now it's about 18 inches deep.
Wags's bar project
Postby wags83 » Mon Apr 09, 2018 10:23 pm
Some updated pics.
Glued up the shelf server-side shelf and started sanding the bar top.
Wags's bar project
Postby Tyler » Tue Apr 10, 2018 7:34 am
I didn't realize how thicc those planks were before. I thought they were from the wall of a barn, those must have been structural.
Wags's bar project
Postby wags83 » Tue Apr 10, 2018 8:48 am
Tyler wrote:Source of the post I didn't realize how thicc those planks were before. I thought they were from the wall of a barn, those must have been structural.
Yeah, I guess I don't know what parts of the barn they were from but they're mostly 2x6's. There are one or two 2x4's and a 2x10 that I haven't used or cleaned up yet.
Wags's bar project
Postby wags83 » Mon Apr 23, 2018 9:45 pm
Some updated pics. Been working on it here and there when I have time. Built the bar structure tonight.
Wags's bar project
Postby Tyler » Tue Apr 24, 2018 7:10 am
I assume your garage floor isn't level so nothing is going to be level when you bring it inside.
Wags's bar project
Postby wags83 » Tue Apr 24, 2018 7:20 am
Haha probably. The beers will just tip over whenever they get set on the bar.
Wags's bar project
Postby Tyler » Tue Apr 24, 2018 7:26 am
Looking great though. Making it up as you go or working off plans you drew?
Wags's bar project
Postby wags83 » Tue Apr 24, 2018 7:29 am
Tyler wrote:Source of the post Looking great though. Making it up as you go or working off plans you drew?
A little of both. I had a rough idea drawn up just to get dimensions down on paper but I've made some changes along the way.
Wags's bar project
Postby wags83 » Sun May 06, 2018 6:24 pm
Put the first coat of stain in the bar top. You'll notice I had a little accident and now my work bench has an area that is stained.
Users browsing this forum: No registered users and 6 guests
