Toilets
Toilets
Postby Tyler » Mon Feb 04, 2019 9:40 am
I must have bad luck with toilets. In the old house I replaced the internals of 2 and the new house I'm going to need to do it again. The ones with the big float thing seem like they have more issues than the new designs.
The first time I swapped it out it took me like an hour. I can hopefully do it in 20 minutes now. Has anyone else changed out the internals due to running toilet, hard to flush, etc?
goldenrod
Toilets
Postby goldenrod » Mon Feb 04, 2019 11:27 am
I did all 3 toilets in my house. They kept letting water run. I bought 2 2 packs and went and did my aunts also which was having troubles. Very fast and easy to do.
Toilets
Postby ejhartman91 » Mon Feb 04, 2019 4:04 pm
We only have 2 toilets in our house and the one that runs is the one with the newer internals system.
Sent from my Pixel 3 using Tapatalk
Toilets
Postby wags83 » Mon Feb 04, 2019 4:05 pm
I should probably change out one of ours. The chain sometimes gets stuck under the rubber stopper part and lets a little bit of water continue to run. It's easy enough to just jiggle the handle to make sure it isn't stuck, but would be nice to not have to do that.
Re: Toilets
Postby Tyler » Mon Feb 04, 2019 4:50 pm
Peel and stick. No need to take off the tank. We will see how it goes. Image
Re: RE: Toilets
Postby Tyler » Mon Feb 04, 2019 4:54 pm
goldenrod wrote:I did all 3 toilets in my house. They kept letting water run. I bought 2 2 packs and went and did my aunts also which was having troubles. Very fast and easy to do.
You're all there is man! I want to be like you when I grow up
Re: Toilets
Postby Tyler » Mon Feb 04, 2019 5:50 pm
I bought the wrong thing. Luckily I only needed to replace the left thing, not the flap. I wouldn't have had to take the tank off regardless since I left the flapper alone
Also showing off my toilet bowl cleaners I have on all of the tanks. $7 at Menards. Buy the hot tub tablets to save all the money
goldenrod
Toilets
Postby goldenrod » Mon Feb 04, 2019 5:52 pm
Very nicely done!
Toilets
Postby bmyoungs » Tue Feb 05, 2019 9:10 pm
I replaced our downstairs one recently but not with the fancy new style.
Toilets
Postby Tyler » Tue Feb 05, 2019 10:27 pm
bmyoungs wrote:Source of the post I replaced our downstairs one recently but not with the fancy new style.
EWW Still have the ball float? Do you hate your family? 100% of people with those will die
Re: Toilets
Postby Tyler » Tue Feb 19, 2019 10:38 pm
Corey, are you a believer of the toilet bowl cleaners now?
Re: RE: Re: Toilets
Postby Corey » Wed Feb 20, 2019 7:44 am
Tyler wrote:Corey, are you a believer of the toilet bowl cleaners now?
I like the effects but it does kind of smell like a pool in the bathroom after flushing
Toilets
Postby bmyoungs » Wed Feb 20, 2019 8:15 am
Yeah still a float. We are planning on replacing the toilets at some point so no sense spending more than a few bucks replacing it
Toilets
Postby ejhartman91 » Wed Feb 20, 2019 1:14 pm
Death by toilet flush system?!
Re: RE: Re: RE: Re: Toilets
Postby Tyler » Thu Mar 07, 2019 10:07 pm
97% of the time I don't notice this. I think I swear by these things. Been in the house over a month now and there has been no grime to scrub at all.
Users browsing this forum: No registered users and 7 guests
