Oculus Rift + Touch
Re: Oculus Rift + Touch
Postby Corey » Fri Jul 28, 2017 10:10 am
My setup is below. I told Meg I'd take down the sensor if anyone comes over that we want to impress (although this work is incredibly impressive)
Oculus Rift + Touch
Postby wags83 » Fri Jul 28, 2017 10:16 am
I'd be more impressed if you left it up.
Oculus Rift + Touch
Postby Tyler » Fri Jul 28, 2017 10:20 am
When Jocelyn complained about mine I said "at least it's not as ugly as Corey's" and then showed her those pics. I think it helped my case a little bit.
I like your wall mounts. I should have patented those!
Oculus Rift + Touch
Postby Corey » Fri Jul 28, 2017 10:28 am
Side note, can I take down the sensors and put them back up without issue? They'd be in the same position but maybe pointed a bit differently. Its not a big deal to take it down if I don't need to re-set everything back up again. The other option would be to put a notch in the mounts so it'd always to to the same spot.
Oculus Rift + Touch
Postby Tyler » Fri Jul 28, 2017 10:32 am
Corey wrote:Source of the post Side note, can I take down the sensors and put them back up without issue?
Correct. Before yesterday I was removing them out of the wooden wall stands. When I put them back in the pre-drilled hole they would be in the same spot, but I wouldn't have the sensors pointed at exactly the same angle - that's fine. You can adjust the angle during gameplay and it doesnt break anything.
Postby Tyler » Sun Aug 06, 2017 3:55 pm
Wags, where are the pictures of your setup?
Oculus Rift + Touch
Postby bmyoungs » Sun Aug 06, 2017 4:45 pm
Might have one this week if I sell my old golf clubs
Re: RE: Oculus Rift + Touch
Postby Tyler » Sun Aug 06, 2017 5:24 pm
bmyoungs wrote:Might have one this week if I sell my old golf clubs
What's the likelyhood of selling those?
Oculus Rift + Touch
Postby wags83 » Sun Aug 06, 2017 5:33 pm
I don't have a real good setup just yet. I'll probably get some extensions for the sensors and headset then put it up more permanently.
Oculus Rift + Touch
Postby bmyoungs » Sun Aug 06, 2017 5:52 pm
It's a guy who's 6'5" looking for a decent beginner set. They don't make extended clubs unless you custom order. Here taking a lesson with me Friday so at least decent odds.
Oculus Rift + Touch
Postby Tyler » Mon Aug 07, 2017 7:32 am
I had to move my sensors around last night after I noticing weird tracking issues for the past couple of weeks. I think my sensors were too far apart or something, because after moving my back corner sensor to the closer corner it fixed everything.
I still need to decide if I want to get a 3rd sensor or not. I only would if I was able to rig it up so that the front 2 were always plugged in and connected. There isn't a good way for me to do that with the 3rd sensor always connected without getting a 50 foot extension cable
I want to get some cheap cable channels and paint them the same color as the wall. That would help clean everything up, but those channels cost more than they should. Corey, find me some cheap ones. We would have issues though where the USB cables plug into each other, that isn't fitting in a channel.
Oculus Rift + Touch
Postby wags83 » Mon Aug 07, 2017 8:00 am
I was messing around in Rec Room last night and smacked my hand on the ceiling when I tried to shoot a basketball.
Oculus Rift + Touch
Postby Tyler » Wed Aug 09, 2017 7:06 am
Moved my playing space over by my computer.
Pros:
-sensors are always plugged in. It was a small hassle to plug in the far one and have that cable run across the floor.
-someone can watch TV in the living room while someone is playing
-not as much as an eyesore?
-one of the sensors doesn't need an extension cable at all
Cons:
-slightly smaller space
-don't have opposite corner sensors right now, but I think I'm buying a 3rd anyways.
-I'm using a 16ft active USB cable when I really only need 6ft
Hard to see in the pic, but I painted my wooden mounts the same color as the wall. The white part you see on the bracket is the tab you pull to remove the command strip.
Oculus Rift + Touch
Postby Tyler » Wed Aug 09, 2017 12:35 pm
Tyler wrote:Source of the post don't have opposite corner sensors right now, but I think I'm buying a 3rd anyways.
Just bought. I'll have something like this....
The only trouble area would be if I was facing the couch and picking something off the ground with my left hand.
Oculus Rift + Touch
Postby Tyler » Thu Aug 10, 2017 3:26 pm
Bmyoungs....
Oculus Rift + Touch
Postby bmyoungs » Thu Aug 10, 2017 3:57 pm
Pending sale of golf clubs tomorrow...
Oculus Rift + Touch
Postby wags83 » Thu Aug 10, 2017 4:02 pm
Welcome to the future!
Postby Tyler » Thu Aug 10, 2017 4:31 pm
bmyoungs wrote:Pending sale of golf clubs tomorrow...
Just in case Sarah read this. I get it.
Oculus Rift + Touch
Postby bmyoungs » Sat Aug 12, 2017 11:51 am
Should get to play tonight
Sarah
Oculus Rift + Touch
Postby Sarah » Sat Aug 12, 2017 9:10 pm
I didn't even ask for a PowerPoint though?
Return to “Video Games and VR/AR”
Users browsing this forum: No registered users and 4 guests
