Robot Vacuums
Robot Vacuums
Postby Tyler » Sun Jan 07, 2018 10:14 am
I think a few of us have some now. What ones and how do you like it?
I use to mock Corey for having one and then he got a 2nd one and I didn't see the point. For Christmas this year I was gifted the Eufy 11+ and love it. I don't think it gets into the carpet as well as our nice vacuum, but it does a good enough job everyday that you come home to a clean house and I love seeing the tracks in the carpet knowing it ran.
More than a handful of times I've came home to find him stuck on the bathroom rug, I just need to remember to close that door when I leave to work.
I think at least once a week I'm going to put him in the basement and let him do his thing. In the basement he can get stuck behind the couch tho, I think I'm going to shove a 2x4 or something back there. You won't be able to see it and it will stop him from getting completely under it.
I know Corey and Bmyoungs get fancy with the schedules, I just have it go everyday at 9am. I'm either at work during that time or in the basement so it works out fine.
TL;DR. I never would have bought one for myself but I'm so glad it was gifted to us.
Robot Vacuums
Postby bmyoungs » Sun Jan 07, 2018 11:50 am
I have the Ecovac Deebot N79. I love it. It was on sale on BF for $150 so it was certainly a steal. I tested the other one I bought and their capabilities are quite different. Most notably difference was the deebot senses walls BEFORE it then does a separate run where it edge cleans. The other vacuum would just ran into a wall before changing direction.
Mine also has a very simple app which allows me to be more creative with schedules. I currently have it set to run 3 times a week. No need to run it every day we aren't THAT dirty. I also like having the app for the occasion we go away for a few days and I forgot to adjust the schedule since it would only need to run once.
Downside of the cheaper vacuum, currently no Google home support although I'm not sure why since other ecovacs are supported. It doesn't work with my harmony hub either. I could try an ifttt but I'm lazy. It also has no rhyme or reason to where it cleans. It just roams around until the battery is too low to continue.
I have recommended everyone I know get one though now. And I don't see a huge reason to get a Roomba specifically unless you get any vacuum that can have a set route to save on cleaning times.
Re: Robot Vacuums
Postby Tyler » Sun Jan 07, 2018 12:34 pm
Bmyoungs, is that the exact same model that The Wirecutter recommends?
If we didn't have Roscoe I would find a way to run it on a schedule similar to yours, but it's nice staying on top of the dog hair now.
Robot Vacuums
Postby bmyoungs » Sun Jan 07, 2018 3:53 pm
Tyler wrote:Bmyoungs, is that the exact same model that The Wirecutter recommends?
Yes it is the same one from Wirecutter.
Kath525
Robot Vacuums
Postby Kath525 » Sun Jan 07, 2018 4:31 pm
What should we get
Sent from my iPhone using Tapatalk
Re: RE: Robot Vacuums
Postby Tyler » Sun Jan 07, 2018 5:46 pm
Kath525 wrote:What should we get
Same one as bmyoungs.
https://thewirecutter.com/reviews/best-robot-vacuum/
Re: Robot Vacuums
Postby Tyler » Sat Jan 13, 2018 10:21 am
I was getting frustrated with mine dying after 30-45 minutes. He would stop and turn red and beep. I assumed the battery was somehow dead. I got smart enough to look up the beep codes in the manual and figured out his brush was jammed. Was easy to clean and he's now back to day 1 performance.
Robot Vacuums
Postby Corey » Sat Jan 13, 2018 10:53 am
Tyler wrote:Source of the post I was getting frustrated with mine dying after 30-45 minutes. He would stop and turn red and beep. I assumed the battery was somehow dead. I got smart enough to look up the beep codes in the manual and figured out his brush was jammed. Was easy to clean and he's now back to day 1 performance.
Mine has the beep codes on the bottom of the robot also so check there.
Re: Robot Vacuums
Postby Tyler » Sat Jan 13, 2018 3:14 pm
Slight upgrade today. Evie will freak when she notices it. Image
Robot Vacuums
Postby wags83 » Sun Jan 14, 2018 10:08 am
Lol!
Re: Robot Vacuums
Postby Tyler » Fri Feb 09, 2018 12:25 pm
How often do you guys swap out the front spinning things?
Re: RE: Re: Robot Vacuums
Postby Corey » Fri Feb 09, 2018 12:49 pm
Tyler wrote:How often do you guys swap out the front spinning things?
I never have
Robot Vacuums
Postby Tyler » Fri Feb 09, 2018 1:19 pm
Corey wrote:Source of the post I never have
Did yours come with spares? Mine are pretty beat up, but I refuse to swamp them after only a few months
Robot Vacuums
Postby Corey » Fri Feb 09, 2018 4:48 pm
Yes I think it came with a set of spares and I am the same way but have had them for way longer than you. They are curled but still do something I think.
Robot Vacuums
Postby bmyoungs » Fri Feb 09, 2018 6:05 pm
I figured every 4-6 months. Or just wait and replace the whole vacuum after a couple years
Re: Robot Vacuums
Postby Tyler » Fri Feb 09, 2018 7:41 pm
I wonder if you can flip them and have them curl the opposite way?
Re: Robot Vacuums
Postby Tyler » Sun Feb 18, 2018 12:27 pm
New $99 one taking Amazon by storm
Biggest con is no dock. Need to manually plug in and charge
http://bgr.com/2018/02/17/robot-vacuum- ... rime-sale/
Robot Vacuums
Postby bmyoungs » Sun Feb 18, 2018 7:56 pm
Tyler wrote:New $99 one taking Amazon by storm
Nice entry for sure. Someone get it and test it
Postby Tyler » Sun Feb 18, 2018 9:49 pm
bmyoungs wrote:Nice entry for sure. Someone get it and test it
I would consider it for the basement, but it says low carpet. Plus without a dock I'm getting the same benefit to just put my Eufy in the basement once a week over night and have it run until it dies.
blake
Robot Vacuums
Postby blake » Mon Feb 19, 2018 11:36 am
Tyler wrote:Source of the post New $99 one taking Amazon by storm
wow if we didn't just get a vacuum from Costco a few months ago, would honestly purchase this
Users browsing this forum: No registered users and 7 guests
